proper way to break in engine/cam (roller cam)(new engine)
its a brand new engine.. 1996 reman engine from ford (5.0HO) Gt40 heads
im doing a cam swap..
how to break in the engine and cam ?? run normal for 1000 miles??
+1, but i also do a 500 mile oil change as well. ive got about 30 miles on my current motor and its been under boost/wot 10+ times. the rings need to seat and thatll only happen if you put it under heavy load. i read somewhere that the first 25 miles are the most important so beat on it before you hit 25miles
ohhh soo beat on it..? i tought i had to drive like a sissy for 500 miles... but beat on it but not high rpms right? im gonna set the limiter at 4000 for safe for the first 100 miles
I run them for about thirty minutes on conventional oil and break in lube while checking for leaks and a few trips around the block. Pull the filter and check it. Change the oil with a good synthetic and good filter then go out and bounce it off the rev limiter. Ive built engines on Sat Morning and run them WFO Sat Night at the strip.
