coolent flush?
Old 02-06-2009, 03:40 PM
kweb288
kweb288's Avatar
Default coolent flush?
Ok just want to make sure i am doing this right, after draining the system i take a gardan hose and stick it in the radiator cap, turn it on and turn the car on, i let this go until clear water is coming out.
Now my question is what part of the system do i leave undone? is it the bottom hose going from the bottom water pump to the bottom of the radiator?
Thanks for the help guys!
kweb288 is offline
Old 02-06-2009, 03:49 PM
mustangsneverdie
mustangsneverdie's Avatar
when i done it I just took out the drain plug and it helped out a lot
mustangsneverdie is offline
Old 02-06-2009, 03:52 PM
kweb288
kweb288's Avatar
wouldnt that not allow the water to get into the block? cause it would only go through the radiator? sorry im a real noob when it comes to coolent flushing lol
kweb288 is offline
Old 02-06-2009, 03:56 PM
mustangsneverdie
it always worked for me cause I mean if you take off the bottom rad hose goin to the water pump then no water at all ain't gonna get into a block.You might be able to take off the hose right behind the tensioner
Old 02-06-2009, 06:13 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
i TAP INTO THE HEATER CORE LINES using the fitting supplied in the Prestone flush kit and then a spout goes on the radiator neck
mjr46 is offline
Old 02-06-2009, 06:16 PM
kweb288
kweb288's Avatar
thanks guys for the help!
kweb288 is offline
Old 02-06-2009, 07:44 PM
AdderMk2
Banned
AdderMk2's Avatar
I disconnect the upper line at the rad and run the hose into the rad itself.... once it runs clear, I remove the two block drain plugs and the rad drain plug.
AdderMk2 is offline
Old 02-07-2009, 11:00 AM
WhiteWindsor
WhiteWindsor's Avatar
I've always removed both radiator hoses. Put the nozzle in top of radiator and flush for a while and then put nozzle at bottom of radiator and cover rest of the hole and flush it till the water is clear coming out of the top of radiator. Of course this is without starting engine.
WhiteWindsor is offline
Old 02-07-2009, 03:41 PM
Jfsram
Jfsram's Avatar
Definately peel a hose off. Rad cap to rad drain plug will not flush the block. Even with the engine running the hose water is so cold most of the time the thermostat will stay closed.
For a real thorough flush pull off both heater hoses and push water threw is both directions.
When you are done flushing make sure you fill it with a 50/50 mix of distilled water and antifreeze.
Jfsram is offline
Old 02-12-2009, 06:44 PM
canman87
canman87's Avatar
I flushed my the same as MJR46
canman87 is offline
Quick Reply: coolent flush?
