well i got the trans tore apat
well i tore it apart today today it wasnt to bad i just hope that i remember were everything goes there is 1 gear that is messed up it sits at the bottom of the trans and it is all by itself what is that called
this is the gear that needs replaced but i dont know what it is called
it is the reverse idler......don't worry about it, reverse always looks like that since it is a non syncronized gear, put it back in the way it was, and I hope you laid all of it out in a line= easiest way to reassemble
yes, I leave the larger hub on since it is positioned correctly to start with, otherwise you'll have to mark it and make sure you get it back on in the very same spot cause if you don't it'll throw alignment of everything off, so I leave it on as long as it's not damaged and everything always goes back on dead on
