motor build
Old 02-07-2009, 09:26 PM
ramz28
ramz28's Avatar
Default motor build
hey every1, i havnt been here in a long time. I finally may get some work done with my stang. 86 hatch. I am looking into doing a rebuild but goin supercharged. I need to bring the compression down to around 8:1. I was going to keep it on the same 302 no bore or stroke. Ive seen the formulas to get ur compression ratio but it needs actual measurements. so would a flat top piston bring me down to 8:1 or close? any help thanks
also forgot to mention i will be switching to carb and running a roots style charger.
ramz28 is offline
Old 02-07-2009, 09:37 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
so your gonna run the weiand 174??, what heads you plan to run??? a dished piston is the first place to start but depending on the cc of head you choose will reflect what cc dish is needed on the piston
mjr46 is offline
Old 02-09-2009, 10:29 AM
ramz28
ramz28's Avatar
Im lookin at this head EDL-60229 exhaust is 60cc and intake is 170cc. Is there something nicer in the same price range? 400-600? what ccs should u be looken at? im goin for a decent budget build something no more then 5k hopefully
ramz28 is offline
firehorse02
11-16-2015 11:28 AM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
logan409
09-26-2015 07:43 PM
Quick Reply: motor build
