i fixed the bucking issue..... or did I?
my check valve went bad in my Fuel pump and the fuel pressure would bleed down to zero in about a minute after turning off the motor.
My car was off for maybe 4 hrs, before i went out and decided to look at it.
THe fuel pump is new.
I didn't use plumbers tape on the schrader valve. i'm going to use the tape and get a precise number and hour.
But it is normal for it do bleed down a little or not at all?
also is it normal for the fuel pressure to rise after i turn the car off. i watched it this time and it rose from 27 to 30.5 in a matter of secs
Edit: alright 20 min have passed since i first posted this and its at 23 psi. so from 30.5 to 23 psi in 20 min. is this normal?
Matt's 95 Stang
10-05-2015 07:16 AM
