so i was having issues with it bucking and poping in the manifold when i shift between 2nd and 3rd so today i decided to mess with the fuel pressure. First i bumped it up to 45 psi vac off and it chugged. then i turned it down to 36 with vac off and it almost eliminated it. I moved it a little further down, maybe 34 vac off,30 vac on and it didn't buck. Is there anything wrong with running it this low? Also i don't know 100% but it felt a little slower (could be me imagining).
Does fuel pressure have impact on i guess horsepower?
normally I run it a little higher with vaccum off and if you run it to low, it could lean it out and cause hesitations
So do you think i'll be alright with the way i described above and is it normal to drop 4 psi when you plug the vac on?
or is it unsafe and i should live with the hesistation/bucking.
Have you ever seen this prob before?/ or do you think i'm just underlying the real problem? (that i don't know of)
i might be able to bring it up to 35 psi.
