smog pump seizure ?
smog pump seizure ?
my smog pump seized about 3 miles fromhouse, decided to drive it home broke belt, then just wrestled it home. will i need to retime it and whats the chance of water pumpdamage it did over heat the radiator and spewd for about 40 ft. it a 94 mustang gt. is there anything else i should check?thanks for any help and i just ordered the smog pump delete kit.
hopefully you didn't blow the head gaskets, what you did was stupid!!, with a broken belt no water circulates,anyway what's done is done, put a new smog pump on and new belt and bleed the cooling system and if it doesn't overheat after repair then you may have dodged a bullet
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
