Fuel Pump Won't Stop!
Old 02-11-2009, 01:45 PM
Catchpole
Catchpole's Avatar
Default Fuel Pump Won't Stop!
You know when you turn the key into the on position and your fuel pump makes that noise for a second, mine is doing that constantly if the battery is connected.
I compression started my car because my battery died, and then it started doing that.
What's causing this, how do I fix it, And is it safe to drive?
The fuel system is completely stock.
Catchpole is offline
Old 02-11-2009, 01:55 PM
Catchpole
Catchpole's Avatar
I went back out to and reconnected the battery to trouble shoot and it didn't happen.
I'm hoping this is just an Uh Oh, but just in case I'd still like to know about this if anyone knows.
Old 02-11-2009, 02:12 PM
wildcobrar
wildcobrar's Avatar
Sometimes when a Fuel Pump relay starts to go bad the contacts in the relay stick closed causing the power supply to be constant to the fuel pump. I would be looking there first if you have that happen again.
Joe
wildcobrar is offline
Old 02-11-2009, 02:48 PM
Ketis
Ketis's Avatar
yeah, soulds like the fuel pump relay to me
it should be under the drivers seat in your car
Ketis is offline
Old 02-11-2009, 05:13 PM
Catchpole
Catchpole's Avatar
The Relay idea struck me while I was on the treadmill at the gym, I picked one up on the way home and that seemed to do the trick.
Old 02-11-2009, 05:22 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
what you need to do is make sure you hve a good battery and it IS FULLY CHARGED.....WHY YOU ASK??? relays and ecm and or computer controlled actuators can do some wierd things when nominal/ 12 v is not up to par
mjr46 is offline
Old 02-11-2009, 05:25 PM
FORD TOUGH
FORD TOUGH's Avatar
Try switching relays to see if it is a fuel pump relay.
FORD TOUGH is offline
Old 02-11-2009, 05:53 PM
Catchpole
Catchpole's Avatar
I didn't know that about the battery, I'll be buying one this week. The one in there right now is too small and it's old anyhow, I've just been putting it off.
Old 02-11-2009, 06:19 PM
FORD TOUGH
FORD TOUGH's Avatar
Check it with a volt meter. A fully charged battery has 12.6 volts.
1TUFF302
11-05-2015 04:02 PM
9550
10-26-2015 05:01 PM
tramphardrocker
09-13-2015 08:56 PM
raleigh05GTO
09-04-2015 07:09 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Fuel Pump Won't Stop!
