Quick PCV Question
Quick PCV Question
OK, I'm trying to rehook up the PCV valve system on my car. Now I've hit a problem, the hole for the PCV valve on the regular GT lower intake has no problem, valve slides right in and seals, however the hole for the GT-40 lower intake is huge, WTF am I supposed to do? Did a parts check and it shows both using the same valve, however there is no way in holy hell that the PCV valve I have now is going to fit in that hole.
You need to remove the grommet/seal and stainless mesh basket from the stock intake and put it in the GT40. It should pull out pretty easy.
If you want to buy new ones.....grommet F7CZ-6A892-AA stainless screen E6ZZ-6A631-B
Casey
Casey
