Throw Out Bearing
Old 02-12-2009, 10:17 PM
89 5.0 Mustang
89 5.0 Mustang's Avatar
so basically everything up to the end of the block.
then does it jus pull out.
and if i have an aluminum fly wheel
would u put that in even tho the clutch wont be new or should i wait on that one?
89 5.0 Mustang is offline
Old 02-12-2009, 10:18 PM
cch
cch's Avatar
Since you gotta drop the driveshaft might as well change up the Ujoints (assuming they've never been changed like most cars I know). Just a thought.
cch is offline
Old 02-13-2009, 05:15 PM
Jfsram
Jfsram's Avatar
Lube the bear support shaft. The tube the bearing slides on.
Jfsram is offline
Old 02-14-2009, 04:49 PM
minnow81469
minnow81469's Avatar
id change the clutch if you going to switch flywheels which is an extra 360 for the clutch, throw out bearing, pilot bearing(spec stage 2 clutch kit) then like 15 bucks for clutch and flywheel bolts
minnow81469 is offline
mrtrodonet
09-19-2020 03:12 PM
6bangr
02-15-2016 07:40 AM
KingRando
10-02-2015 08:06 AM
Drastang
09-30-2015 03:48 AM
Offendant
09-23-2015 07:21 PM
Quick Reply: Throw Out Bearing
