Should I windage tray?
Old 02-13-2009, 05:12 PM
  #21
Jfsram
Jfsram's Avatar
I read about a back to back comparison, windage tray vs nothing on a 440 Dodge.
It was in a Mopar mag years ago. They took a typical 12 second 6000rpm mild 440. They swapped the tray onto the engine right there at the track.
Do not remember the mph but it was a 0.15 sec difference. After reading that I'm a firm believer in oil control. Especially since it's a no drawback modification. Meaning unlike a cam or steep gears a tray will constantly remind you it's there.
Jfsram is offline
Old 02-13-2009, 05:17 PM
  #22
djcondo
djcondo's Avatar
yeah thats what i was thinking. you cant really go wrong
djcondo is offline
Old 02-13-2009, 07:41 PM
  #23
1BIGMOFO
1BIGMOFO's Avatar
I currently have a new OEM style ford racing oil pan w/ stock capasity. I also got a new pickup tube and a high flo ford racing oil pump. Shoudl I look into a higher capasity pan w/ a different pickup and a tray?
1BIGMOFO is offline
Old 02-15-2009, 02:06 AM
  #24
Jfsram
Jfsram's Avatar
What I meant to say is unlike a cam and steep gears which constantly remind you they are there. You will forget you have the tray in there as it continues to help with horsepower.
The higher capacity pan Strongstang speaks of. I really don't know why they call them higher capacity pans. They should be call. Keep the oil resorvoir away from the crank pans.
If you install a deep pan. Add more oil. All you've done is increased your capacity. Whoopty do. Seriously, what have you gained with this.
Now install the deep pan, run the same amount of oil as stock. You have effectively created a sort of a dry sump system. The oil reservoir is away from the crank. This equals power gain.
Jfsram is offline
Old 02-15-2009, 07:27 AM
  #25
1BIGMOFO
1BIGMOFO's Avatar
JFSRAM,
If you get a deeper pan and keep the same capasity as stock in theroy you shouldnt even need a windage tray correct? Do they sell pan / pickup tube combos?
1BIGMOFO is offline
  #26
1BIGMOFO
1BIGMOFO's Avatar
^^ sorry do they sell aftermarket high capasity pan / pickup tube combos?
1BIGMOFO is offline
Old 02-15-2009, 09:22 AM
  #27
Portmaster
Portmaster's Avatar
Yes they do, but if you want to use a stock pan just put a crank scaper on it. easy 5 hp
Portmaster is offline
Old 02-15-2009, 09:54 AM
  #28
1BIGMOFO
1BIGMOFO's Avatar
well I have a brand new stock pan thats why i was considering the tray. I guess ill keep the stock pan and just call Summit and see what they can get me for the 306
1BIGMOFO is offline
Old 02-16-2009, 02:09 PM
  #29
Jfsram
Jfsram's Avatar
Pans usually come together with a tube. As for both of them together. I don't know.
Jfsram is offline
Tyoung68
08-25-2015 04:31 AM
haus85z
04-02-2006 10:15 PM
doc_phibz
12-17-2005 01:09 PM
schwindty
12-05-2005 06:35 PM
Drive85mustang50
10-08-2005 09:57 PM
Quick Reply: Should I windage tray?
