valley girdle for 331 stroker?
#22
i think you should get one if thats what you want to do if anything it will give you piece of mind im going to get one myself because i believe it will help even if its minimal most people that talk bad about them have never used one so if 200 is no prob then id go for it
#23
I had a girdle here is what it looked like. did it hold things together? well I guess the only thing left that was good was the heads and the cam and lifters and the intake it wiped the rest out even the distributor and I fixed the oil pan just to put a new one on later. this was after 3 years hard running and count less runs. would I buy one again No, plus I got the one I had I got on the cheap.
#24
I'm sure you have what you say you have , and don't take this the wrong way , I mean no disrespect, but I feel based on your comments that it's you who don't have much experience in the FORD world. Why?? Because if you knew anything about the limitations of a stock block , you'd never of built a beast of such in a stock block and on top of that thrown a 200 shot on top of it. tO PUT THINGS IN PERSEPECTIVE, the moment you crack the bottle and mash the gas to the floor I can almost gaurantee before you hit the 1/8th that block will let go even with a valley and or main girdle. Seriously save your money for a good block to transfer those parts too, before your out those parts and a block, the blocks people have pictured/posted let go with far less hp THROWN at them then you are, learn from the pics
#26
ya your right im 20yrs old and im not the most experienced person on here by far and the comment i made to guy calling b/s i regret how i said it i also ment no disrespect but the motor has been ran like this for awile now without the juice though it has been ran n/a 611hp and 577tq now with the juice i believe everybody saying that it will go pop as for the motor i didnt build it a family friend/shop owner hokeracing.com built it it was originally inteded for someone else who ended up selling it back to bill (hokeracing) owner i have seen the dyno sheet n/a and it does make the power i say it has a **** ton a machine work done to it as for the nitrious i was going to add that myself so im not going to now after getting everyones input so i hope i didnt come off like a know it all *** because im not sorry if i came off that way guys
#28
