89 mustang 5.0 5 speed in a 5.0 gt?
idk much about tranny swap but i found a good deal for a 89 5.0 and i been wanting to make my 95 manual for a bit now so will this work? the 89 is for 600$
Ok, so it sounds like....you have a tranny from an 89' 5.0 and you want to put it in your 95 5.0. If so then yes i believe you should be fine, but do know you have to get clutch pedals,cable, quadrant which should be part of the pedals, and possibly a different cross member(not sure about what cross member your working with).
From what I have been told because I have a 94 with a auto also ...You have to change the pcm to one from a manual trans because the one you have now will mess you up with the shift points that are programed in it
It shouldnt be that far off, I had a 96' v6 tranny in my car with the bellhousing(because of the input shaft deal) from that car, and it fit fine, other than my crossmember had to be modified but...shouldnt be an issue
both transmissions are the same except the input shaft is longer for the 94/95.
ShaneB26154
35
03-04-2021 04:05 AM
