Fan clutch and battery question
I changed my fan clutch today it has been bad for sometime. i wasn't getting cold a/c heat and my car was overheating (though i did make sure there was coolant there at all times) because of it. So I tested it out and it worked great i got heat and cold a/c but as soon as i turn on the a/c i see the battery voltage go down, my father said because the battery didn't have to run as hard because of the bad fan clutch whereas the new one takes more power to have it spin. My alternator is brand new and the battery is in good shape (or so i believe) is this a common problem when you change your fan clutch? I'm going tommorow to get the alternator and battery tested to see if its them but anyone ever had this problem?
its a 91 and its a mechanical fan the volts dropped a great deal. i dont know exactly how much but before the lights and a/c are turned on its right on the middle of the gauge as soon as both come on it drops to a quarter of the gauge but its only when the car isnt moving
Sounds like the alternator isn't charging at all. The fan clutch would have nothing to do with it. Just because the alternator is new doesn't mean it's charging and the fact that it is new tells me that the charging problem was an issue before the fan clutch went bad. It's time for a charging system diagnosis.
11-10-2015 11:39 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
