aluminum driveshaft questions
with gear changes to say a 3.73 up will cause some extra vibration what the aluminum driveshaft does is dampen the vibrations...also other benefit is less rotating mass meaning less drive train loss so 1-3 hp more at the wheel
out of 5 foxes i did the aluminum drive shaft on 2 one was just the drive shaft because of a vibration and it fixed my vibration problem on the other i did a aluminum flywheel and drive shaft and it made the motor alot more responsive it reved and dereved alot faster plus like wowvfast said less rotating mass so = a little more power to the rear wheels
The reason an aluminum driveshaft is recommended/needed when you do a gear swap is because the driveshaft will be spinning at a higher rpm as opposed to with stock gears. The stock driveshaft isnt made to spin that fast without the frequency reaching its vibration point which is why you usually feel a vibration with gear swaps. The aluminum driveshaft is stronger and usually has a larger diameter which keeps it from twisting or bowing like the stock one and causing a vibration.
Theres actually a formula for the length and diameter dirveshaft you need depending on the rpm it will be turning. Ill try to find it and post it later.
wow lots of useful info and thanks for all the posts guys! i really want to find one now, my stepdad is still opposing the idea, but im going to go with you guys because, well everyone on here has had experience. lol and he doesnt know jack for fords. :P hes a mopar guy. not that im a hater, hes just not knowledgeable in Fords.
now ive just gotta find one cheaper than $250 on summit. hah anyone selling? i can get one out of a aerostar too right?
A car is a car, regardless of make. Cars arent magic and different based on where they are manufactured. There are certain truths that are applicable to all cars, and then some that are applicable to cars that are similar.
check out car-part.com for the shaft.
firstly....look at my sig.....mopar guys, we tend to know whats going on .
and yea i checked out car-part.com and theres a bunch of em around me but none close
i might just put in my stock one for now, and if its bad ill just throw in an alum. one
