Newbie here having major problems
i have a 1989 mustang that was a 4cyl turned into a v8 it has a 302 with a t-5 maual its got a holley carb on it and the car dont run but maybe 5 minutes then stalls out and dont start for a few minutes im new to carbs and kinda lost with all of this any help would be appreciated
it happens just at idle the car has spark so it seems to be a fuel problem but i dont know anything about carburators so im kinda lost about this weather it needs more fuel pressure or if the carb is bad or needs rebuilt
can't hurt to rebuild the thing if its been sitting for a long time or at least clean it out with some 2+2.
If it starts to die on you have you tried clearing it out? by that I mean give it half gas let the accelerator pump put the gas in it and then floor it for a second to burn up any residual gas which may have built up. Sounds to me like it may be loading up on you. what size carb is it cfm wise?
