i run them on all 4 corners. i run 3 in the front, 6 in the rear at the track and 6 in the front for the street. its nice to be able to tune your suspension by simply turning a ***
You can also take your front sway bar off.... just dont take turns at crazy speeds i run mine right in the middle all the time until i get to the track
what springs you running lucky? do you have adj. u/l control arms?
stock springs in the rear with 4 banger springs in the front. uppers arent adjustable but i have southside style lowers that allow for some adjustability. i run no sway bar in the front, in the rear i run the stock sway bar plus an anti roll bar
the struts should still be able to fully extend even with lowering spring with the front end totally unsprung. however it'd be tough to do that since they dont have stored energy ilke drag spring. so you'd be able to tune for autox but your spring dont help you for weight x-fer from front to rear.
Kinda the same thing I was thinking......hmm, might be looking into getting some drag springs.
i cant remember if you run off a t brake but if you have one and figure out that 2 step you could launch the **** out of that thing if you get around to some sticky tires. probably then you'd want some adj. uppers to change your IC once you get to that point.
