('95 5.0) Removing window motor, have I botched things up?
What's up all! The window motor has all but about died in my '95 5.0 Convertible. Taking the door panel off was easy breasy. I read a few guides, which were all different and then jumped right in.
First I drilled out the two rivets in the middle of the door that hold the regulator on.
Second I drilled out the right two rivets that hold the regulator on. Maybe I shouldn't have drilled out these two?
Third I took off the little bottom track held on by two nuts, real easy. Dunno if this needed to come off but opened up a lot of working room.
Next I unbolted the three bolts that hold the motor to the regulator. Boy I didn't understand what was going to happen at this point. The motor came off and the spring on the regulator closed up. Made a bunch of crazy racket.
I tested the motor and it is almost dead and my new motor is real strong. Tomrrow I will be trying to put everything back.
I'm worried that I will have trouble bending the arm back, hooking the motor up, and getting the gears to line up to the regulator. Sure seems crazy that it will all go back together and work! I'll let you know.
