car wont start!!!!!help
Old 02-21-2009, 10:39 AM
mustangt95
mustangt95's Avatar
Default car wont start!!!!!help
i was driving my car yesterday and i had just left the light and my car just died. it would start back up.
i know its still getting fuel and its trying to crank...
now when we was looking we found the rotor in the distibutor was missing the tip so i replaced it and it ran for about 30 min to a hour and it died again..so we replaced it again and it still didnt work so we went and put a new rotor and cap on and still wont start.
i can use any help much appreciated...this is my only car and it wont start
thx
chris
mustangt95 is offline
Old 02-21-2009, 10:43 AM
95greengt
95greengt's Avatar
what does the inside of your cap look like ... i usually replace cap and rotor together
95greengt is offline
Old 02-21-2009, 10:44 AM
SonicBlueFiveSlow
SonicBlueFiveSlow's Avatar
http://sbftech.com/index.php/topic,588.0.html
SonicBlueFiveSlow is offline
Old 02-21-2009, 10:54 AM
Timspony
SVT Section Moderator
Timspony's Avatar
...I'm thinking it could be the TFI module
Timspony is offline
Old 02-21-2009, 11:48 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if you are positive it's not fuel related, could be tfi or stator in dizzy
mjr46 is offline
Old 02-22-2009, 08:33 AM
mustangt95
mustangt95's Avatar
well i did replace the rotor and cap the second time the car died on me.
i believe the problem is either the coil or the distributor...
what does the module all control. cus am not getting spark from my coil.
Old 02-22-2009, 09:04 AM
Portmaster
Portmaster's Avatar
If it fired back up when you replaced the rotor with the "Missing tip" I hope you thought to find the missing tip. It's couldn't have gone far. It may have got caught up in the pick up coil and trashed it. The module going out at the same time is not impossible but highly improbible.
Portmaster is offline
Old 02-22-2009, 07:24 PM
mustangt95
mustangt95's Avatar
well i have been doing some test at my coil is out of specs and i believe the ball bearings in the distributor are bad also..cus the all the symptoms of a bad bearing just happen to already happened
djbigskrilla
09-20-2022 01:04 AM
drumhedd2005
08-13-2015 09:59 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
89blueslug
08-10-2015 07:20 AM
Quick Reply: car wont start!!!!!help
