what else needed besides trickflow kit?
Old 02-21-2009, 08:52 PM
Red95GT5.0
Red95GT5.0's Avatar
Default what else needed besides trickflow kit?
I was thinking of getting the trick flow kit for my 95 GT, and was wondering what all i would need like (injectors, MAF, Fuel pump, etc.) thanks for the input
Red95GT5.0 is offline
Old 02-21-2009, 09:09 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
just fluids and some RTV
mjr46 is offline
Old 02-22-2009, 06:07 AM
Portmaster
Portmaster's Avatar
Looking at your signature line you pretty much have it covered. The TrickFlow kits really have you covered. Sometimes the kits come with ARP headbolt sealer and sometimes they don't. I'd wait until the kit showed up but don't skip it. Using a thread chaser (7/16 X14) Not a thread tap! chase all the head bolt holes to clean them out before you install the heads. your head gaskets will thank you
Portmaster is offline
Old 02-22-2009, 09:43 AM
capri debris
capri debris's Avatar
I called the guys at Trick Flow to find out what they recommend when I did mine and I suggest that you call them also to confirm the lists I have below.
1. 24# injectors
2. 70mm TB
3. 75mm MAF tuned to 24# inj.
4. minimum 190 lph fuel pump, 255 is better
5. adjustable fuel pressure regulator and gauge
6. a good dyno tune
side note: the cam thrust plate will need to be machined (I did mine by hand with a dremmel) to accept the new bolts supplied with the kit that have a taper head. Also, the marks on the timing chain gears don't look like the diagram in the instructions, so make sure you set them at 0* and not retarded or advanced for the cam timing. Everything else is pretty straight forward, just be sure to check P to V clearance and set the rockers EXACTLY the way they say in the instructions. Good luck.
capri debris is offline
djbigskrilla
09-20-2022 01:04 AM
drfister
05-03-2018 10:38 PM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
defarmer
08-13-2015 06:40 AM
Quick Reply: what else needed besides trickflow kit?
