Another Speedo?
Another Speedo?
I have a 90 LX 5.0 and the speedmeter does not work. I have 373 gears and looked up and purchased he correct cable gear and installed it in the transmission. I can spin the speedo gear which slips into the trans just fine, but the speedo does not move at all... Anyone had a similar problem? Is this a speedo cable problem or is the meter itslef broken? Any ideas how to diagnose this problem?
is the gear inside the tranny still clipped in place on the output shaft??? shine a small light in and look with a mirror, then undo the dash end and put tranny end back together and drive it and see if cable turns if all is well to that point = bad head unit
