My recession build
Old 02-26-2009, 01:59 PM
ponyboy88
ponyboy88's Avatar
Default My recession build
So, my mustang has been off the road for a little over 3 months now. Honestly i miss her too much and need to get her back on the road, i was going to rebuild the motor and get a stroker in their but i have figured out what was causing some of the immediate problems. I'm gonna fix those to prepare the car for the stroker and when i have the money, i'll order my stroker.
Some questions first.
Has anyone tried this combo pack from summit
http://store.summitracing.com/partde...0&autoview=sku
I need a new cooling system because my clutch fan flew off, and my radiator leaks.
And im looking at a disk rear, 3.73's out of a 96 cobra. The guy wants 600 for it...sounds a little absurd to me, but when i figure into doing the gear swap any way it seems almost worth it.
Thoughts?
ponyboy88 is offline
Old 02-26-2009, 03:10 PM
ahittz24
ahittz24's Avatar
I would never pay $600 for a used axle, ebay would be your best friend in that area. you can rebuild the axle you have with new gears and bearings for less than that and then hit a boneyard for the brakes
ahittz24 is offline
Old 02-26-2009, 03:14 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
96 is gonna be a wider rear than a fox rear
mjr46 is offline
Old 02-26-2009, 03:58 PM
Timspony
SVT Section Moderator
Timspony's Avatar
$600 a lttle $$$, but when you consider cost of gears & install, + being a Cobra, it's ok! As far a being a little wider, you can make up the difference with different wheels backspacing! ...FFRP sells a '95 Cobra R wheel with a just for the Fox (5 lug)
Timspony is offline
Old 02-26-2009, 05:09 PM
symonds86
symonds86's Avatar
i have a 96 axle shafts and disk brakes on my fox its a lil wider but will work
symonds86 is offline
Old 02-27-2009, 09:43 AM
ponyboy88
ponyboy88's Avatar
that's what I've heard. Just wondering, by the time i ship an axle from ebay to my parts thats 400, plus 500 to rebuild it and get the gears in it.
Old 02-27-2009, 04:07 PM
Portmaster
Portmaster's Avatar
Look around and find you a running 90 model Lincoln Mark VII. You can pick up a running version for 500-800. Has the rear disc rear you want and a spare engine and all kinds of other neat stuff you can use. You could sell the air bags and almost get your money back.
Portmaster is offline
Old 02-27-2009, 04:31 PM
ponyboy88
ponyboy88's Avatar
the pimps done brought up all the Lincolns in my parts.
Old 02-27-2009, 04:34 PM
ponyboy88
ponyboy88's Avatar
just 90. theres an 89 for sale actually, not bad looking.
Old 02-28-2009, 01:07 PM
ponyboy88
ponyboy88's Avatar
bump... can i use an 89?
Quick Reply: My recession build
