Transmission problems?
I have an auto 4 cylinder v8, and when I shift to double drive, it seems to be in neutral and just revs real fast, but doesn't seem to propel the car.
Also, when in second, at about 2,000 RPM's, it will make this awful clanking sound.
Any ideas?
Any ideas?
The oil was low and I had to ask someone what kind it takes haha...
Is the transmission fluid on the right side, with the yellow handle?
I think it's on the passanger side, but you check it running as for the mounts, you get under the car and inspect them and I often use a pry bar to lightly lift up on them to see if they are broken.
