94 cutting out
94 cutting out
hi i have a 1994 mustang gt that is having some problems. when driving the car it cuts out and jolts you at all rpm's and when i push the clutch in it revs up to 2500 rpm and wont go down until i tap the gas and even then it wont go to normal idle for a few seconds. on top of that when you first start the car it idles fine but then it starts to idle kind of like it has a cam but then it idles so low it almost dies but then picks itself back up. i have replaced the i/a/c and cleaned the maf and new 02 sensors. any help at all will really help. thanks
cuts out as in dies completely?? or cuts out and outta the blur comes back to life??? if that's the case the stator in the dizzy is a common prob that exibits such or the tfi module.......as for the hanging idle , that is part of the dash pot function on a 94 and what I'd do first is run a koer test and look for any codes that might clue you in on where the prob may be
jwog666
12-27-2021 08:09 PM
