my jay allen cam specs are in!! take a look
Old 03-03-2009, 02:21 PM
blk89lx
blk89lx's Avatar
Default my jay allen cam specs are in!! take a look
let me know what you think..
Customer Name Ford Strokers (Snyder)
3 Cubic Inch and Engine Type 347 CID SBF
4 Camshaft Type Hydraulic Roller (Billet Core)
5 Firing Order STD 351W/302 HO Ford
6 Cam Bearing STD 351W/302 HO Ford
7 Lobe Separation 113.66
8 Overlap at .050" 7.91 Degrees
10 Camshaft Measurement Intake Exhaust
11 Duration at .006" 279.01 308.16
12 Duration at .020" 253.73 275.49
13 Duration at .050" 226.14 244.30
14 Duration at .200" 152.40 158.69
15 Lobe Lift .37768" .36972"
16 Rocker Ratio 1.60 1.60
17 Gross Lift .604" .592"
18 Lash HOT HYD HYD
19 Net Lift .604" .592"
20 Designed Lobe Centerline 111.18 ATDC 116.13 BTDC
21 Open at .050" 1.89 BTDC 58.28 BBDC
22 Close at .050" 44.25 ABDC 6.02 ATDC
23 Lift at Top Dead Center -> .0552" @ 111.18 In.Center .0731" @ 116.13 Ex.Center
24
25 Cranking Compression 196 PSI
26 Vacuum at Idle 13.1 Inches
27 Idle RPM 800 RPM
28 Peak Torque RPM 4900 RPM
29 Peak Horsepower RPM 6300 RPM
30 Starting Shift Point RPM 6800 RPM
31 Maximum Usable RPM 7200 RPM
blk89lx is offline
Old 03-03-2009, 02:53 PM
kweb288
kweb288's Avatar
looks like a fun cam!!!!!!
what is the rest of the combination? as far as engine
kweb288 is offline
Old 03-03-2009, 02:58 PM
blk89lx
blk89lx's Avatar
347 from ford strokers scat internals probe srs flat tops
fully ported victor jr heads
edelbrock super victor efi manifold with elbow
42lb injectors
sup tank a1000 pump
1 3/4 longtubes
3 inch exhaust
blk89lx is offline
GimpyHSHS
19
12-19-2023 01:12 PM
baddog671
07-26-2016 01:20 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: my jay allen cam specs are in!! take a look
