valve lash
Old 03-03-2009, 07:43 PM
redemption
redemption's Avatar
Default valve lash
can somone elaborate on how to set valve lash, ive heard different techniques on how to do it, but not sure which one to follow.
im doing 1.6 roller rocker on a 302 on afr 165 heads
thanks
chad
redemption is offline
Old 03-03-2009, 07:46 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
pedastal mount??
mjr46 is offline
Old 03-03-2009, 07:47 PM
redemption
redemption's Avatar
oops sorry thhere stud
Old 03-03-2009, 07:54 PM
mjr46
mjr46's Avatar
start with no 1 cylinder and watching the lifter roll motor over until the lifter for the exhaust valve starts to open, you are now on the heel/base circle of the intake lobe and can now set lash, tighten poly lock down until slight drag is felt on the lifter then from there 1/4 to 1/2 turn more to set pre load then lock it down, you are then ready to do the exhaust valve, roll motor over until intake lifter starts to move up , when it does you are now ready to set lash/preload, continue the same procedure for the rest of the cylinders
mjr46 is offline
Old 03-03-2009, 07:57 PM
redemption
redemption's Avatar
Thanks a lot man. Much appreciated!
Old 03-03-2009, 08:09 PM
mjr46
mjr46's Avatar
http://www.flowtechinduction.com/technical.htm#Valve
mjr46 is offline
Old 03-03-2009, 09:09 PM
Slo5oh
Banned
Slo5oh's Avatar
second EOIC.
if you do it in order you will set lash by turning the cam over only once.
Dont get excited and overtighten the nuts because you are able to get the pushrods to press down more when you do so, thats only because the lifters arent pumped up.
If you go over a rocker and set it, and later notice it is loose dont worry, thats just because you have compressed that lifter some more and there is less pressure built up in it than when you set your lash.
Slo5oh is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
svfetter
10-05-2015 11:39 AM
lmurf60
09-24-2015 10:07 PM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: valve lash
