intake spacer bolt size?
03-04-2009, 08:39 PM
i picked up some intake spacers, 1" thick. any idea on the size (lenth,width,tread) i will need?
03-04-2009, 08:40 PM
03-04-2009, 08:51 PM
One inch bigger in length bolt. Just take the old bolt to napa and get it 1inch longer
03-04-2009, 08:56 PM
i was hoping to have the bolts so i can take it off and put it back on right away.
btw, droptop. that car would look sick with some black headlight covers
03-04-2009, 09:10 PM
Quote:
Originally Posted by
j-wigg
Getting black one peace headlights...
03-05-2009, 12:25 PM
yeah just go to a parts store or most likely a hardware store would have them before a parts store would. but just get them an inch longer and your set.
03-05-2009, 02:33 PM
how many are there and are they all the same?
03-05-2009, 02:38 PM
will i need to change any other gaskets? i've got the gaskets for the spacer. will anything else be needed??
thanks
03-05-2009, 02:40 PM
summitracing says this under their suggested parts for a trickflow model TFS-51520002.
part TFS-51522001-4
Gaskets, Upper to Lower, OE/Stock EFI Intake Manifold, Ford, Mustang, 5.0L, Set of 4
03-05-2009, 04:00 PM
More than likely you will have to order these.
The long ones stock are about 7 1/4". Further more you want to use Grade 5 at a minimum otherwise they could snap. You could try Lowe's or Home Depot.
