temp problem
Old 03-05-2009, 10:54 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
sit at idle and see if it comes on
mjr46 is offline
Old 03-07-2009, 06:54 PM
malo012000
malo012000's Avatar
When to get tested and no oil in the rad and heads are good but the fan only comes on when the temp gets half way and goes off after the temp goes down a littlt ...the fan wont let the car over heat but will let it stay at half way why? also when the fan comes on it is in high speed
malo012000 is offline
Old 03-07-2009, 07:40 PM
mastermic
mastermic's Avatar
I dont understand? Your car is running within the normal range, fan is kicking on, its not overheating. If you want it to run a little cooler go with a lower temperature thermostat.
mastermic is offline
Old 03-07-2009, 07:58 PM
malo012000
malo012000's Avatar
Yes the car is in the normal range but when I get on it it goes up to the L in normal and will come down I think that is too close to hot for me or is it normal you tell me..also I changed the t stat to a 180 from a 195 and no change
Old 03-07-2009, 10:30 PM
mastermic
mastermic's Avatar
That should have changed the operating temp the 180 thermo that is, did you test your coolant temp sensor? Use an ohmeter cold it should be around 74 ohms, as the engine heats up the resistance will drop and should read around 9.7 ohms.
Old 03-07-2009, 10:50 PM
w8less
w8less's Avatar
does it have air in the coolant system? i would check the fan settings? maybe the t-stat is sticking. just throwing ideas out there
w8less is offline
Old 03-07-2009, 10:58 PM
malo012000
malo012000's Avatar
OK is that the one above the t stat housing on the tube that goes to the heater core and do I just take the plug off and ohm the polls that the plug hooks on or what and thanks for the feed back
Old 03-08-2009, 12:53 PM
mjr46
mjr46's Avatar
also i'D VERIFY IF YOUR STOCK GAUGE IS CORRECT, IT MAY ALL BE A GAUGE ISSUE
mjr46 is offline
Old 03-08-2009, 02:31 PM
malo012000
malo012000's Avatar
I have check the gauge with a thermomiter in the tank of radiator and the water gets to 212 then the fan comes on ...Also I changed the coolant temp sensor and no change has happen but when I disconected the sensor the fan came on ,on low then went to high so I think the fan is ok as far as the speeds in it ...so now Im stumped If I kept the coolant temp sensor disconected what will that mess up or does anyone have any other ideas to try HELP>>>>>>>>>>>>>>>>>>>>>
Old 03-08-2009, 03:48 PM
wowvfast
wowvfast's Avatar
it's not the fan....does this car have a stat in it? what psi is the rad cap? other than these 2 you might have a partially plug rad..
wowvfast is offline
Quick Reply: temp problem
