Spongy Brake problem
My car has a spongy brake pedal.. It still has alittle stopping power once you press it far enough.
Do you think its the master cylinder or does the brakes need to be bleed? I'm kinda confused about this situation. The car sat for year or so.
if it has sat for an extended period of time check the MC and see if it's full of fluid if it is and after bleeding it you still have a spongy pedal, replace MC, but verify there are no external leaks first which would clue you in on such if the MC was low or empty
mungodrums
10-07-2015 04:01 AM
musnicki
09-23-2015 07:11 AM
