seal
seal
i had changed my balancer about 3 weeks ago and ever since i changed it i got a oil leak where the balancer is which i think is going to be the front seal, how hard is it to change that seal
For future referance you should always change the seal when changing a balancer. A lesson I'm sure you already know about. Put a very thin coat of RTV on the seal (like paper thin) around the seal where it goes into the timing cover. They can leak around the seal where the seal meets the aluminum cover. It most cases it won't but why risk it.
so i just pop it out then, i thought i was going to have to take off timing cover, and i knew i should of changed it when i installed new balancer but i didnt see no leaks or have any leaks and got lazy , i guess when i slid on new balancer or pulled old one the seal must off loosen up
jwog666
12-27-2021 08:09 PM
bradleyb
11-27-2015 07:50 PM
