Clutch adjustment
Old 03-07-2009, 12:02 PM
mastermic
mastermic's Avatar
Default Clutch adjustment
I have a stock 95 Mustang Gt with the T5 and self adjusting clutch mechanism. I pull up on the pedal it releases but doesnt seem to adjust anything. I just want to get a little slack out of the cable. My pedal makes a little ticking noise when not depressed I can just slightly push it(maybe a 1/4 inch)and the noise stops. The car shifts fine and the the clutch operates properly. Is there any other way to take a little slack out and bring the pedal down slightly than the self adjuster.
mastermic is offline
Old 03-07-2009, 04:08 PM
mastermic
mastermic's Avatar
Any ideas?
Old 03-07-2009, 04:23 PM
mastermic
mastermic's Avatar
would it be best to just by a steeda adjustable cable kit
Old 03-08-2009, 10:17 PM
Jfsram
Jfsram's Avatar
You are "in between teeth" right now. Not loose enough to engage the ratchet mechanism but too loose to preload the bearing.
Either wait, buy and adjustable set up or ignore it.
Jfsram is offline
Old 03-09-2009, 08:45 AM
mastermic
mastermic's Avatar
Thanks. I will probably just wait until the clutch goes out and replace the cable and quadrant with adjustable one then.
Old 03-09-2009, 10:06 AM
AdderMk2
Banned
AdderMk2's Avatar
why wait till the clutch goes out.... you can do the cable, adjuster and quad swap in an hour
AdderMk2 is offline
Old 03-09-2009, 12:05 PM
FordMustangXBA
FordMustangXBA's Avatar
Just get an adjustable cable...took me 20 mins to change mine.
FordMustangXBA is offline
Old 03-10-2009, 08:25 PM
Big_Steve
Big_Steve's Avatar
I actually just bought a new BBK adjustable cable, you guys say 20 minutes-1 hour to do, but i own a fox, im assuming the sn95 is different under the dash than the fox. Under my dash is a complete cluster F***
Big_Steve is offline
Old 03-10-2009, 08:30 PM
mastermic
mastermic's Avatar
Must be different on my 95 looks like only 20-30 minute job.
Old 03-10-2009, 08:49 PM
Stangnsnow2
Stangnsnow2's Avatar
you might have striped some teeth on your clutch quadrant. i have a heavey clutch and striped the teeth out and the adjuster wouldnt adjust
Stangnsnow2 is offline
Quick Reply: Clutch adjustment
