New Battery Question???
Old 03-07-2009, 10:28 PM
Detroit_Muscle
Detroit_Muscle's Avatar
Question New Battery Question???
I just ordered Red Top Optima Battery, Top and Side Terminals, 800 Cold Cranking Amps, 10 in. x 6.875 in. x 7.813 in., Each 12 volt Optima. I am wondering if this battery is good for my 1991 stang. Is the crank enough and is there anything else I need to consider?
Thanks G
Detroit_Muscle is offline
Old 03-07-2009, 10:34 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
the red top is plenty!!!! I have the red top in my 85, and never an issue with cranking
mjr46 is offline
Old 03-07-2009, 10:41 PM
Detroit_Muscle
ok thanks
Old 03-07-2009, 10:51 PM
w8less
w8less's Avatar
arent they like overly obese batteries? have you relocated the battery to take advantage to some of the weight?
w8less is offline
Old 03-07-2009, 11:15 PM
AdderMk2
Banned
AdderMk2's Avatar
a regular battery will do the job just fine..
and you should do some research on the optimas... now that you have a red top... DONT do a 3g alternator swap... otherwise you will start to kill the battery. The new optimas are garbage
AdderMk2 is offline
Old 03-08-2009, 12:57 AM
Chaoss84GT50
Chaoss84GT50's Avatar
Whats the big no-no about a 3G with an optima red top? This is the setup I was going to go with. What Battery do you suggest if I plan on a 3G alt upgrade? I dont mean to thread jack.
Chaoss84GT50 is offline
Old 03-08-2009, 05:15 AM
AdderMk2
Banned
AdderMk2's Avatar
a normal battery
Re: new battery needed - Optima Red Top? any help?
AdderMk2 is offline
Old 03-08-2009, 08:01 AM
Portmaster
Portmaster's Avatar
I have red tops in my wifes 03 Mustang, Our Caravan, My Truck and one will go in my Fox. I ran one trunk mounted in my last Chevelle and it spun a 540 cubic inch Big Block with 11.0-1 compression without an issue using a 150 amp alternator. I was a Optima dealer. I sold over 500 of them and had three returns. 2 of them were returned because they were just dead do to bad alternators and one had a loose post. I have a Blue Top in my boat as well. Best batteries I've seen. My wifes mustang and Our Caravan both have high amp alternators and never a momonts problem with them. Don't beleive everything you read on the interweb.
Portmaster is offline
Old 03-08-2009, 08:38 AM
Timspony
SVT Section Moderator
Timspony's Avatar
...I thought everything was the truth!! ...also, don't believe everything you read in the Mustang Mags., they tend to tell some white lies as well
...Part no. on the Red top for your '03 Mustang....I want to get one for the '03 Cobra!
Timspony is offline
Old 03-08-2009, 10:46 AM
Portmaster
Portmaster's Avatar
75/25 I made a hold down for the battery. OEM wont work. It was no big deal. I took some thread rod, a few washers and nuts and a short piece of aluminum over the battery and made a hold down in the OEM platic tray. I covered the threaded rod with some black shrink wrap and polished the plate and used some black nail polish over the nuts and it looks great. It's a show winner so it must be decent. Took me about an hour to build the hold down.
Quick Reply: New Battery Question???
