Is this gap on my engine normal? (pic)
Old 03-10-2009, 06:08 AM
Timspony
SVT Section Moderator
Timspony's Avatar
Hi-temp RTV ftw! ...cork = junk!
Timspony is offline
Old 03-10-2009, 06:56 AM
sschanz
sschanz's Avatar
Honestly, I didn't know that you could skip a gasket altogether and just use RTV. Is there anywhere that RTV alone wouldn't be a good idea? Wish this stuff came by the gallon! Any particular recommendation from the group on which RTV to get? I have the blue stuff - will that work?
sschanz is offline
Old 03-10-2009, 07:45 AM
86HOGT
86HOGT's Avatar
I use good gaskets and the Right Right Stuff. The Fel Pro ones I believe have lips on them so they straddle the block slide and won't slide.
86HOGT is offline
Old 03-10-2009, 08:40 AM
Portmaster
Portmaster's Avatar
I like Permatex Ultra Black, Ultra Gray and Ultra High tep red. The only place I use RTV to replace a gasket all together is on the end of intakes, rear dif covers and places where it was OEM used. I use it at the corners of the oil pan gaskets. I don't use it to replace an oil pan gasket, timing cover gasket or even a water pump gasket. I may use a very very light coat on a water pump gasket. There is nothing worse looking than an engine with RTV pouring out around the oil pan, valve covers, timing cover, etc. Not only that but if it's pouring out on the outside it looks just like that on the inside and when it breaks off on the inside from all the hot oil and cold cycles it winds up in the oil pan and will stop up the oil pick-up. It's great stuff but don't try to replace a quality gasket with it. Cork gaskets have no place on the ends of intakes. Before RTV small blocks fords were plaqued with oil leaking at the ends of the intake. It was a rare thing to see a 289/302 or 351W that didn't have a puddle of oil on top of the timing cover.
Portmaster is offline
Old 03-10-2009, 08:53 AM
sschanz
sschanz's Avatar
That was a good take on it. Thanks for that. I like your comment on RTV breaking off in the inside as well. Great point.
sschanz is offline
drfister
05-03-2018 10:38 PM
antipeterleague
08-18-2015 01:50 PM
WDScott
08-17-2015 06:38 AM
svtrosey
SVT Forums
08-15-2015 09:09 PM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: Is this gap on my engine normal? (pic)
