Buying canfield 192's this week! what cam and rockers?
HI, i am buying some canfield 192's this week and need some advice on a few things 1> what do you think of my head choice? 2. what cam should i get, i want it to be the best cam i can get the most power from, but i dont want piston to valve clearance issue's, what cam should i get my current mods are in my sig and im buying canfield heads this week the 192's one last thing what rockers to go with the cam, one last thing, how much of a power difference will i feel with my soon to be heads, cam and rockers over my current upgrades, I really want only people that know well of what they are talking about when it comes to this, i Am grateful for the help, Thanks guys
Chances are you are going to have PTV clearance issues with them regardless of what cam you use because of the 2.02 intake valve. I think you would be better off with a smaller set of Twisted wedge heads from trick flow or AFR 165's. Cam choice will be a little tougher depending on where you want the torque curve. As far as rockers go I'd go a set of quality 1.6 full roller rockers. How much differance in power. That will all depend on how well your parts match. But you can just about count on PTV clearance issues witht he Canfields. You may want to rethink that move unless you are will to buy another set of pistons or notching what you have.
1. Id get the AFR 185's and notch the pistons. That is what I have and with these heads you have room to grow and the 165's 302 is about topped out.
2. Id get the TFS stage 2 (notched pistons needed). I have the x-cam, but next time I have my motor apart that is what Im puttin in.
Get full roller rockers 1.6's.
Yes huge power difference with the 185's. If you are not willing to notch the pistons you are limited on power upgrade choices.
Why?
