Shut off problems
Old 03-11-2009, 01:06 PM
ROrtega
ROrtega's Avatar
Unhappy Shut off problems
To anyone who has suffered the following. I have a 66 with a crate engine swap from summit (5.0 302 gt-40 heads etc.) I have a mallory comp s/s 42 magnetic breakerless ignition & coil to match with 9mm wires. I'm having a problem with The engine not suting off right away. It stumbles or takes about 3 secs. to shut off at a stumble. I recently started driving the car and have only set timing by ear. Anyone have any suggestions or experience with this?
ROrtega is offline
Old 03-11-2009, 01:15 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
make sure the float level is set properly if it is a carbed car and use a light to set timing, not by ear, that may be half the issue.
mjr46 is offline
Old 03-11-2009, 03:28 PM
ROrtega
ROrtega's Avatar
Thumbs up Thanks, MJR46
It is a carbed engine. I didn't think of setting the floats and the carb has recently been worked on. I will try the light and floats.
ROrtega is offline
Old 03-11-2009, 06:54 PM
wowvfast
wowvfast's Avatar
try this..turn the car off in gear and get back to me..
wowvfast is offline
Old 03-11-2009, 06:58 PM
mjr46
mjr46's Avatar
mjr46 is offline
Old 03-11-2009, 07:04 PM
wowvfast
wowvfast's Avatar
your point? useless as it may be
wowvfast is offline
Old 03-11-2009, 08:58 PM
droptop302
droptop302's Avatar
Do you like 2 **** off MJR?
droptop302 is offline
Old 03-11-2009, 09:41 PM
mjr46
mjr46's Avatar
Now this is useless "help"....I only try to help people with proper diagnostic techniques in accordance with my training
I have helped in 90% of my posts....
TRUTH EXPOSED^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
you care....and it wan't answered...hillbilly*L*
enlighten me then..I'm all ears....never to old to learn something
yeah it's called your right foot*L*
loud doesn't mean fast, you may think your fast but your not..
carb cleaner
is it fixed?
I love the 1986 capri one....
there lies my dating issues....
I would tell you but my magic crystal ball is in the shop
..dude you need a cam lesson or two*L*...
yes...
dish pistons will flow ok
a foxbody owner here
mjr46 is offline
Old 03-22-2009, 12:26 AM
ROrtega
ROrtega's Avatar
I turn the car off in drive and the engine shuts off fine without a stumble. I began to do this when pulling into busy lots where I might be embarrassed by the sound of stumbling to a stop. It takes the cool out of driving. The car is carbed and seems to smoothen out after going well over 25 mph. It doesn't feel so smooth when drivin away slowly. I had a c4 prepped w shift kit awhile back before I installed my crate engine. I remember it moving smoother in drive before. I did have an igition box but it's out now. I haven't messed with the electric choke yet for the carb. Anyway thanks for your help.
ROrtega is offline
Old 03-22-2009, 12:38 AM
NotchAbove
NotchAbove's Avatar
I'd check that timing before I go any further.
NotchAbove is offline
Quick Reply: Shut off problems
