Bottom end
Old 03-12-2009, 09:54 PM
minnow81469
minnow81469's Avatar
Default Bottom end
Need to know a short block or a kit to throw in my bottom end to hold up to at least 15lbs of boost from a turbo setup any help would be awesome
minnow81469 is offline
Old 03-12-2009, 10:09 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
get a better block first = dart
mjr46 is offline
Old 03-12-2009, 10:11 PM
minnow81469
alright what about crank dish pistons and h beam rods
Old 03-12-2009, 10:12 PM
minnow81469
aluminum or cast blocks?
Old 03-12-2009, 10:17 PM
mjr46
mjr46's Avatar
cast iron block, no need for aluminum, decide what your hp goal will be and then choose block accordingly and rest of build from there
mjr46 is offline
Old 03-12-2009, 10:33 PM
NoGo95GT
NoGo95GT's Avatar
I am running a Trickflow H/C/I and pushing 15lbs of boost through a Vortech. Car runs fine. It all depends on the tune and how much power you want to make. 400-475rwhp=can use stock block. Anything more look for a stronger block, like a Boss and forged internals.
NoGo95GT is offline
Old 03-12-2009, 10:38 PM
minnow81469
yeah see i dont know how much boost it will actually push but 15 lbs min out of it
Old 03-12-2009, 10:42 PM
kweb288
kweb288's Avatar
could always start out with just the turbo... and possibley a lower boost level and work up from there? ..... just a thought
kweb288 is offline
Old 03-12-2009, 10:44 PM
NoGo95GT
NoGo95GT's Avatar
With your mods and a turbo@8psi, it will make close to 500rwhp easily. I would look into getting a stronger block and FORGED internals if you want a minimum of 15psi.
NoGo95GT is offline
Old 03-15-2009, 10:54 AM
minnow81469
Well yeah its go big or go home now at this point im just having problems finding the right stuff that i need
Quick Reply: Bottom end
