I currently have AC delete and a smog delete pullys installed. When I put the new 306 in I would like to delete the pullys all together. What belt will i need and will I need any different bolts etc?
when you have the motor setup the way you want it with the pulleys you want, take a wire (not a string it will stretch) and run the wire around the pulleys the way the belt would route. then take the wire off and measure it. only way to know for sure what size belt you need
Since you're deleting the original belt will be longer, therefore make one cut in it and use that to measure. Just remember that a new belt will stretch.
