Lower Radiator Hose Always Cold
Old 03-15-2009, 10:28 AM
stang8689
stang8689's Avatar
Default Lower Radiator Hose Always Cold
Even when my engine is fully warm and the upper hose is hot the lower is cold I thought it was the thermostat but my dad said its not cause the reveserse rotation. he says I have air in my coolant anyone know what it could be. I have a Ford Racing aluminum radiator thats pretty new
stang8689 is offline
Old 03-15-2009, 10:32 AM
NotchAbove
NotchAbove's Avatar
If there is air clogged, just run the engine with the radiator cap off, it should burp out.
Is this a new problem ?
NotchAbove is offline
Old 03-15-2009, 11:22 AM
86HOGT
86HOGT's Avatar
I just installed a new aluminum radiator myself and the temp drops real quick from the inlet (upper hose) to the oulet (lower hose). Is it overheating at all?
I haven't been able to road test the new aluminum/Taurus fan yet since the roads are still salty to see if my lower hose stays cool which I can't imagine it staying real cold but it shoud heat up some.
86HOGT is offline
Old 03-15-2009, 12:25 PM
stang8689
stang8689's Avatar
Its a new problem but the car sat for a while while I was painting and I did a new water pump so the coolant was changed and has done this since. Not really over heating but sometimes my car will excessivelly smoke white but only once in a while and I did a coolant pressure check and it held perfect pass the cap pressure
Old 03-15-2009, 12:36 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
temp on lower should be cooler cause after it passes through radiator it should cool coolant down. as for the smoke how much??? does it fog the place out??
mjr46 is offline
Old 03-15-2009, 05:45 PM
stang8689
stang8689's Avatar
yeah the smoke does but it rarely does it I will drive it for a month and it wont smoke then one day it will then stop but the lower is cold not even warm is that normal
Old 03-15-2009, 07:55 PM
mjr46
mjr46's Avatar
it should be warm to some extent, not ice cold, but that'll all depend on temp outside what I'd do is if you have a infared thermometer is probe different spots on the cooling system, may have a restriction, also perform a block check with a kit to test for a blown head gasket.
mjr46 is offline
Old 03-15-2009, 09:02 PM
stang8689
stang8689's Avatar
well i did the coolant pressure check and it didnt budge at all even at 20 psi of pressure gaskets have like 2k miles on them but I dont know this car has been killing me for 3 years lol just tryin to get it right and enjoy the almost 20k in it and hundreds of hours on it
Old 03-15-2009, 09:59 PM
mjr46
mjr46's Avatar
I know what you mean, my motor is out once again in a quest for more hp, I work on it more than I get to enjoy it.
mjr46 is offline
Old 03-16-2009, 06:18 AM
stang8689
stang8689's Avatar
Yeah I should want to drive it without any problems i will try to get the air out the coolant and see if that does anything
Granatelli Sales
01-20-2020 12:34 AM
Demodulates
09-18-2015 11:14 AM
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Lower Radiator Hose Always Cold
