free easy mods???
Old 03-15-2009, 05:14 PM
rdmypny
rdmypny's Avatar
Question free easy mods???
i have a 1990 GT 5speed. i am wondering is there any free or cheap mods that can be done performace wise?
rdmypny is offline
Old 03-15-2009, 05:23 PM
NoGo95GT
NoGo95GT's Avatar
You have pretty much maxed out your free mods. You could bump the timing to 12-14 degrees, remove the front sway bar(I'd only do it for the track though), run a shorter belt and bypass the smog(Again I'd only do it at the track). You could also run some premium fuel and octane booster to eliminate any knocking or pinging(due to bumped up timing). But as you probably know, you have to pay to play!
NoGo95GT is offline
Old 03-15-2009, 05:25 PM
Portmaster
Portmaster's Avatar
Kick up the timing, take out weight, keep in tune,
Portmaster is offline
Old 03-15-2009, 05:46 PM
rdmypny
rdmypny's Avatar
yea my smog pump is already off. all my mods are in my sig. i run 93 octane only im my car. and yea i do know you have to pay to play. does anyone have any idea what i might run at the track? i am scared to take it because i had a 98 GT 5speed and the mods were CAI, O/R H-Pipe, dynomax bullet mufflers, stage III clutch, 4.10 gears, auburn pro series LS locker and i was running 9.30's in the 1/8th and 14.30's in the 1/4 on street tires with 20psi. i am afraid this car wont do it and it will hurt my feelings. what do you guys think?
rdmypny is offline
Old 03-15-2009, 06:22 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
as stated above, timing and weight reduction after that, it's pay to play
mjr46 is offline
Old 03-15-2009, 06:34 PM
mustangsneverdie
mustangsneverdie's Avatar
you shouldn't be too far behind your old 98 get you some drag radials and you'll leave t in the dust(so to speak)
mustangsneverdie is offline
Old 03-15-2009, 07:39 PM
rdmypny
rdmypny's Avatar
whats the best thing to do to take out weight?
rdmypny is offline
Old 03-15-2009, 08:21 PM
mustangsneverdie
smog, a/c, and p/s pump,you can take out the pass. seat before you go to the track and run like a 1/4 tank of gas
Old 03-16-2009, 08:21 AM
ahittz24
ahittz24's Avatar
I beleive someone once said, "Speed cost money, how fast do you want to go?"
ahittz24 is offline
Old 03-16-2009, 09:43 AM
USMCrebel
Mach I Section Moderator
USMCrebel's Avatar
where are you in al?
if you can't get under 9.30's with the **** you got now.....it's pointless to add anything else until you can drive it how it sits.
USMCrebel is offline
Quick Reply: free easy mods???
