na street build
na street build
i want to build a motor for my car. its going to stay n/a. should i use a 5.0 block or a 5.8. im going to run afr heads probly 58cc with high compression and i like steedas 18 and 20 cams. ill probly get a tubular gt40 intake port matched to the heads. ill probly need 24# injectors. what are your opinions
scrap the gt40 intake, it will choke a build if you want to do it right. I'd say get 347 can use the 5.0 block if you're on a budget use an aftermarket block if you want to make higher hp numbers down the road.
i couldnt agree more. check out hardcore50.com and sbftech.com if you dont learn something from those 2 sites sell the car to someone else
Learning Curve...
I'm starting to learn how I found such a great home on my other forum.
I'm a Mustang newbie too. I've built several 302's a couple of decades ago in High School that ran for years and years. But I have no earthly clue what the good components are today.
Rather than just shoot a guy down, how about providing him with some of your great insight too. "Yes, that combo sucks, but here's a combo that would be great for you." "Instead of using blah blah blah, try yada yada yada, you'll yield better torque more cost effectively".
This is one of many posts i've read in the the past 2 days where we shoot a person in the foot for making a mistake then suggest they give up or sell the car. WOW!
Listen we were all newbs at one point building hotrods. Granted some of you guys spent decades perfecting combinations that work. Years worth of money, blood, and sweat was spent learning the hard way to get where your cars are right now, and i've seen some really impressive machines here. But if the purpose of this forum (in part) is not to help people learn from your combined awesome extensive knowledge, well then why are we bothering logging in?
Thanks by the way to the guys who have emailed me and posted for me great ideas, deals and suggestions.
/rant off
/rant off
Why should every single thing be spelled out? fs308 gave him a good recommendation. Fact of the matter is: with some research and more reading his question has been answered and are readily available with the use of the search function. Why should everything be spoon fed?
Here I will spoon feed a little, how the hell do you select a cam, injector, and head without knowing what block you are going to use? Research your parts and find out what their application is and come up with a goal for what you want the car to do.
