Need help locating fuel pump fuse
my buddy thinks he might have blown a fuse for the fuel pump. ran a wire to the + on the battery and the pink/black wire on the relay and the pump works but he needs to know where the fuse for the fuel pump is so he can check it. need help asap thanks.
what grounds the relay is the ecm and does such when it recognizes the PIP signal from the stator in the dizzy, this is how the ecm known the engine is cranking and therefore to ground the fp relay........need to make sure the stator and or tfi are generating the correct signals to the ecm.
