Need Some Advise
It took me a while to realise what a dizzy meant too. But it is the distributor. The stock headers, especially on the 87-93 cars are junk. They are very crimped. An aftermarket H-pipe will make the car sound better. However, the stock one flows reasonably well. In fact, the stock Mustang exhaust is one of the best production car exhausts in terms of flow. The Corvette's is better. The World Jr. heads work well and have been around since the early 90's, so they are a proven cylinder head. Hope this helps!
I think it should be your decision. The stock H-pipe will keep you emission's friendly. The dynomax turbos flow nicely, but are not much louder then stock, plus the price sounds reasonable. Also, it will help you to have a nice sleeper tone to your ride. If you really want to save money, then I would keep the stock exhaust. But if you would like a little sound, then the mufflers will add a nice touch.
Def go with the Twisted wedge heads if u can afford them. you can ditch the smog delete bracket all it is is a dummy pulley, you can just get a shorter belt and be done and save yourself $30. and you definitely should get the adjustable fuel pressure regulator you need it to tune ur car.
as for exhaust def get shorty headers equal length. you can keep the stock h-pipe but i would get a new one. i assume ur state requires emissions so get one with 2 high flow cats. and get a cat back of some kind. i kno you are gonna want the sound. check out the sound clip thread.
you are going to want more suspension mods. U/L control arms rnt enough. Springs and shocks/struts (adjustable) and you pretty much NEED sticky tires to get in the 12s. MT ET Street Radials should do
if you can, invest in a REAL ProM MAF www.promracing.com none of the cheap C&L BS
and i would try and find a better intake to match those heads. Try looking for used parts in your area on www.craigslist.org you can get some great deals on good used parts.
hope i helped
hope i helped
alright i have searched around some more and have came up with a better list, i haven't ordered any of this yet but will once i get it right so here is it
INTAKE MODS
Ford Racing Cobra Intake Manifold $409.95
Remove Air Silencer $FREE
Summit Racing Street & Strip Throttle Body 70mm $125.95
K&N Filtercharger Air Filter $52.95
Edelbrock Intake Manifold Bolt Kit $26.95
Mr. Gasket Ultra-Seal Intake Manifold Gaskets $17.95
FUEL MODS
Summit 255lph In-Tank Fuel Pump $107.95
Holley Adjustable Fuel Injection Regulator 35-65psi $66.95
Summit® Chrome Plated Fuel Pressure Gauge $15.95
Summit High-Flow Fuel Injector 24lbs $197.95
C&L MAF 73mm 24lb $124.99
Mr. Gasket High Performance Thermostat 180D $12.95
SUSPENSION MODS
Summit Racing Street & Strip Upper and Lower Control Arms $179.95
EXHAUST MODS
BBK Equal Length Shorty Header 1 5/8in $229.99
BBK CNC Series Off-Road Race H-Pipe 2.5in $179.99
Dynomax Super Turbo Exhaust System $204.95
TUNERS
SCT tuner $269.99
IGNITION MODS
ACCEL U-Groove Performance Spark Plugs $29.95
Ford Racing Spark Plug Wire Sets 9mm $41.95
Summit Racing Street & Strip Ready-to-Run Billet Distributors $170.95
GEARS
3.73's
TIRES
NITTO Extreme Performance NT555R Drag Radials (275/40-17) $340
ENGINE MODS
Edelbrock Performer RPM Cam and Lifter Kit $192.95
Edelbrock Performer-Link True Roller Timing Chain Sets $61.95
Fel-Pro Timing Cover Gaskets $14.95
Proform Smog Pump Eliminator Brackets $53.95
Edelbrock Hardened Steel Pushrods $39.88
ARP Head Bolt Kits $41.95
Edelbrock Cylinder Head Gaskets $55.95
Now im stuck with the cylinder heads its between these
Edelbrock Performer RPM Cylinder Heads $1159
Trick Flow Twisted Wedge Street Cylinder Heads $1,199.95
World Products Windsor Jr Cylinder Heads $879.90
and do i need new rocker arms? if so which ones 1.6 or 1.7s?
INTAKE MODS
FUEL MODS
SUSPENSION MODS
EXHAUST MODS
TUNERS
SCT tuner $269.99
IGNITION MODS
GEARS
3.73's
TIRES
ENGINE MODS
I could easily see 270+rwhp. I made 271rwhp and 311rwtq through an automatic(I had Trickflow heads, cam, GT-40 intake + boltons). At the track I ran a 13.17@105(2.0 60ft) and in 95 degree heat. I used the Nitto drags. Oh, I also have stock suspension, but it was lowered 1.5 inches(Eibach springs).
oh and you can also buy a complete gasket kit for cheaper than you will buy them individually. i just ordered one tonight for $125 cuz it had better head gaskets than some of the other ones. that were a little cheaper. and it comes with EVERYTHING except the upper intake gasket which was $11 extra so i got the right one
