I need help with installing upper and lower intake on 1991 5.0
Old 03-17-2009, 04:49 PM
ballajb
ballajb's Avatar
Default I need help with installing upper and lower intake on 1991 5.0
Ok I have a 1991 5.0 block that I had built up, But I am left to install the upper intake. I have the upper intake and I have the tree looking thing that goes under it. Now i am comfused with what I connect to what. The lower intake is on the block and I know there is a whole in the back of the intake, what goes there? I will not be running a egr, i have the egr delete plate and did the smog pump delete on the motor, so can anyone help me with pics so I can see what goes where and how to run the hoses.
Thanks
ballajb is offline
Old 03-17-2009, 07:32 PM
15austin
15austin's Avatar
The tree looking thing I believe what you mean is for the lifters. It bolts down to the block and holds the lifter dogbones in place.
The big hole in the back is for a pcv valve it just hooks to a vacuum port on the upper intake.
15austin is offline
Old 03-17-2009, 07:55 PM
steel1
steel1's Avatar
Thttp://www.veryuseful.com/mustang/tech/engine/images/mustangFoxFordVacuumDiagram.jpghe Big hole in back of lower intake is for the pcv valve, Try the link for vacuum hook-ups to the upper.
steel1 is offline
drfister
05-03-2018 10:38 PM
JonnyBlazeGT
11-03-2015 01:10 AM
unit91
08-31-2015 10:27 AM
inyadreems
08-21-2015 09:10 AM
dseg
08-08-2015 09:00 PM
Quick Reply: I need help with installing upper and lower intake on 1991 5.0
