BBK O/R H to BBK Shorty exhaust leak
on my 95 gt i have an annoying exhaust leak at the header on the pass side where it bolts to the H pipe. everytihng is tight and has been removed and put back on again and tightened and still leaks. is there anything i can put on it to try and stop the leak? some type of gasket?
thanks
thanks
i don't think it has a gasket all i am familiar with is its like a ball and pops in place. its kind of a dumb question but are the bolts to long and bottoming out? and are you sure its popped in place correctly?
take the H pipe off, sand out the inside of the collector to remove any rust, do the same with the ball on the header, then put some red rtv silicone on it and bolt it back together.
let it dry for atleast 6 hourd
ok great! i will try that this weekend. will this try up rock hard? here in MD i have to swap in my cats every 2 years for emissions. just want to be able to get it all apart again.
thanks for the info adder!
Luke9222
10-22-2015 11:55 PM
09-10-2015 08:39 PM
