turn signal troubleshooting (HELP!)
my g.f's 87 is having a problem with the turn signals, haven't had time to look real hard but this is what i do know.
The turn signals aren't working
The hazards do work
The fuse for the signals is fine.
do i assume its something within the steering column?
The hazards do work
There are 2 flashers, one for the hazards and one for the turn signals. I believe on my 87 the flasher for the hazards is on the back of the fuse panel and the flasher for the turn signals is under the column to the right side. Check that.
Have you had the dash apart lately?
me personally no, the PO installed a Grant wheel on it and the horn doesnt work, so my girlfriend pulled the wheel to see if she could figure it out, i'll try the other relay and then oherwise im guessing the multi function switch?
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
logan409
09-26-2015 07:43 PM
