need help with my 95 5.0!!
oh and another thing that i noticed while i was driving home today is that i hear a rattling sound coming from underneath the car when i accelerate and its mostly when i try to accelerate in the lower rpms. what could that be? might that be related to the rest of the issues?
A rattling sound huh. Get a hammer and lightly bang on the cat-converters. If they make any internal noise, like loose metal flying around, you could have a clogged cat. Post results. I'd like to see how everything goes.
hey sorry about the long wait i have been really busy this week. i put in new spark plugs, wires, did the oil change and it doesnt hesitate (barely noticeable) but it still doesnt pull like it use to. what can i check now?
Did you do the fuel filter yet? Do you know what your current timing is set at? You could have a clogged cat, but I am a bit hesitant on that one. Just get a hammer and lightly hit each cat. If it rattles inside, chances are one of your cats have fried. Also, a dirty fuel filter can really make your car run bad. But so can your timing. Make sure it is set at 10 degrees at least. You can go up to as high as 16 degrees. But 12-14 is usually a safe bet.
