zex tc window switch problem
Old 03-21-2009, 09:28 PM
tyler08
tyler08's Avatar
Default zex tc window switch problem
Ok just installed the zex kit on my 87 gt. All was well untill I installed the window switch. The wiring is nothing to it, impossible to screw up. Problem is now after wiring and programming the swithch the nmu is firing as so as I hit 46 psi which is where I have my feul safety cut of switch at. Its like the window switch dosnt work, if I jumper the feul safety cutt off switch with the system armed it opens both solnoids. I have check the wiring and reprogrammed the switch, all is correct. Am I missing something or is the window switch toast? Thanks J
tyler08 is offline
Old 03-21-2009, 11:43 PM
NotchAbove
NotchAbove's Avatar
I think you have to first hook it up without the window switch. Test it to get it to open at WOT. Once the solenoids work, hook up the window switch.
NotchAbove is offline
Old 03-22-2009, 01:48 AM
tyler08
tyler08's Avatar
ya I did that?
tyler08 is offline
Old 03-22-2009, 02:34 PM
NotchAbove
NotchAbove's Avatar
So your fuel cutoff is set to turn off the system at 46 ?
I thought normally it would be set to cut off at 30 or so.
Scottyboy187
SVT Forums
11-20-2015 02:57 PM
Scottyboy187
11-05-2015 04:18 PM
HorsePower99
08-26-2015 11:29 PM
HorsePower99
08-26-2015 08:32 PM
MXBT187
08-20-2015 02:36 AM
Quick Reply: zex tc window switch problem
