intake manifold questions
Old 03-21-2009, 11:24 PM
ctlazersplaya07
ctlazersplaya07's Avatar
Default intake manifold questions
so i have done the cold air intake and the 75 mm throttle body and am looking into intake manifolds now. i am just looking to make my car a competitor on the streets, i dont plan on running tens at the track cause i dont have that kind of money to dump into a car yet. so should i go with the trickflow street heat or track heat and why?, and how long does it take to install a manifold. a garage told me six hours but i highly doubt that.
ctlazersplaya07 is offline
Old 03-21-2009, 11:58 PM
NotchAbove
NotchAbove's Avatar
For the price and performance and for your use, a Cobra would be the best to get.
6 hours is about right (working solo). There is a tons of stuff to swap over, that are usually in there pretty good.
NotchAbove is offline
Old 03-22-2009, 12:17 AM
ctlazersplaya07
so if a professional garage did it....how long should it take?
Old 03-22-2009, 12:36 AM
NotchAbove
NotchAbove's Avatar
Like I said 6 is about right for anyone who knows what they are doing.
Old 03-22-2009, 12:49 AM
94StinkinLincoln
94StinkinLincoln's Avatar
depends on what needs to be done, im sure if they have put that intake on that body style before, 2 hours it could be done.
94StinkinLincoln is offline
Old 03-22-2009, 07:18 AM
Portmaster
Portmaster's Avatar
If your car still has the sock heads and cam don't waste you money. You won't feel any noticable differance. If you want to increase performance come up with a plan on what you want out of your car and start collecting parts. I would suggest looking into a good set of heads first then come up with the cam that fits your driving needs and then the intake that matches it. You can then do the install of all the parts at the same time and you will save yourself money. If you shop around carefully you can run into some really good deal on used parts. Learn to do these installs yourself. If you plan on owning a hot rod you need to know these things. I'm sure people here will jump at the chance to guide you through the process.
Portmaster is offline
Old 03-22-2009, 08:46 AM
calfroper_06
calfroper_06's Avatar
if you have no mechanical knowledge at all you can get it done in 6 hours, if every thing there. Like portmaster said do yourself a favor and do it your self, in a ears time youll save you self alot of money and learn as well
calfroper_06 is offline
Old 03-22-2009, 09:34 AM
ctlazersplaya07
so you think i should wait till next year when i have a second car and can leave mine in my garage for a while and work on it there?...what would be a good head cam intake setup for me if i wanted to make it a competitive street car but was not looking to make it a track car?
Old 03-22-2009, 10:13 AM
ctlazersplaya07
and if i install these myself....i dont need to take the engine out myself do i?...cause i dont have a lift for it.
Old 03-22-2009, 12:13 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
h/c/i can be done with engine in the car, as for what is good?? what is your budget first?? and be realistic not cheap
mjr46 is offline
Quick Reply: intake manifold questions
