Installing Rear Shocks, Need advice.
Hi guys,
I am currently in the middle of putting rear shocks in my 87 GT. One side came out just fine, but the other is giving me a hard time. The upper mounting nut is seized to the shock and when I go to loosen the nut, the whole shaft spins. What should I do, I do not have access to a torch or air tools. Would it make a difference if the car was on the ground as opposed to in the air?
Thanks.
Thanks.
Vice grip will work best. I just had the same issue, after doing upper, lower rear control arms and the sway bar. I guess I was getting a lil tired and got careless. I forgot to tighten the nut on the shock. When I set the car down and realised I tightened it. Low and behold I cross threaded it and it siezed. I used a vice grip on the top of the shaft and was able to get it off.. Then I used a tap and die to re-thread the nut and shock shaft. r-einstalled and all is ok..
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
