fixing the rear
Old 03-22-2009, 07:06 PM
1988GTstang
1988GTstang's Avatar
Default fixing the rear
so my rear end isnt in the greatest shape so i bought a kit from LRS
http://www.latemodelrestoration.com/...0%201&comp=LRS
is this everything i will need? the cars the same one in my sig...just wanted to make sure ill be spinning both tires...
1988GTstang is offline
Old 03-22-2009, 07:12 PM
symonds86
symonds86's Avatar
that should be everything ya need minus tools. i donno if ya have done gears before or are doing them yerself but heres a little list. a viener caliper, dial indicator, i like them w/ a magnetic base, and an inch lb dial gauge torque wrench, bearing puller. plus yer normal hand tools to take it apart and reassemble
also you will only be spinning both tires if you have a trac loc or another type of limited slip carrier
symonds86 is offline
Old 03-22-2009, 07:18 PM
1988GTstang
well its a stock rear end as far as i know...did the lx come wit it? if not got an reccomendations? dnt want one wheelers lol
Old 03-22-2009, 07:45 PM
Boss_Hotrod
Boss_Hotrod's Avatar
You will also need a trac-lok rebuild kit. If you want to completely overhaul the rearend get a set of axle bearings and seals as well.
Boss_Hotrod is offline
Old 03-22-2009, 09:09 PM
1988GTstang
so i need to buy a trac-lok kit or the lx came with one and i can buy a re-build kit?
Old 03-22-2009, 09:11 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
clutches for thew trac loc are what you need = 60-80 bucks depending on where you buy them
mjr46 is offline
Old 03-22-2009, 09:36 PM
1988GTstang
so i dnt need the whole unit? just the clutches? also i was thinkin get sum new axles while im at it..any recomendations on that?
Old 03-22-2009, 10:42 PM
Chaoss84GT50
Chaoss84GT50's Avatar
look at the tag on your rear end if it says something like 2L73 (just made up numbers) on the second line then its a trak lok. If it says 2 73 then it is gonna pull one-wheel wonders. Hope that helps.
Chaoss84GT50 is offline
Old 03-23-2009, 08:42 AM
AdderMk2
Banned
AdderMk2's Avatar
all 8.8 rears in the late foxes had trac-lok diffs.... i still have yet to figure out why people think otherwise
AdderMk2 is offline
Old 03-23-2009, 09:35 AM
mjr46
mjr46's Avatar
if what you are trying to correct is the one wheel peel, clutches will solve that
mjr46 is offline
Quick Reply: fixing the rear
